Discuss Latest on USB Sockets in the UK Electrical Forum area at ElectriciansForums.net
h901
Hi,
After doing a search on the forum I can across a few threads about USB plug sockets and the verdict was that they should be avoided, but these threads were all quite old. So I was wondering what's he current verdict on the USB plugs sockets.
Is it worth replacing standard double socket to a double socket with USB? If so, what brands are recommended?
I put a BG one in because it fits a 25mm box, still going has my tablet and mobile in all the time. Mind you the writing below the USB ports has all but gone.
I actually only got the BG because it fits a 25mm box, when I took the old socket off it was on a 35mm box and I fitted the box, must be my age. The curved corner ones look okay though.
I was told by a wholesaler that the reason the MK USB sockets were late to the market was they were obtaining approval from Apple et al. I have not had them long enough to comment on reliability. They fit easily in a 35mm box
The Schneider ones are good.
BG have more choice in finishes though, and more choice in the actual USB socket. I believe they do a 2.1A up to 4.1A.
Screwfix discontinued their 2.1A Lap ones, jeez they were bad. They have replaced with 3.1A ones which seem far better. They do just squeeze into a 25mm box, unless you are dealing with 4mm cable, then defo need 35mm. I actually used a 47mm in the end!
Reply to Latest on USB Sockets in the UK Electrical Forum area at ElectriciansForums.net
Hi there, I am looking for some advice re: putting new sockets and usb sockets in my home. Someone will be rewiring the entire house but I have...
Just wondering what folks think about in terms of 13A sockets with built-in USB charges, what are the good/bad/ugly of choices? I could do with...
I had the unfortunate experience today of trying to fit a customers 13a double sockets, they were hidden screw type with USB outlets...
Hello All and happy new year. Over the holiay I have changed all of my old sockets to some nice new ones and added a couple with usb sockets for...
Hi All, This might be a bit of an odd question, I would really appreciate your thoughts. I am trying to up-date my mum's home, before putting it...
