Discuss LED Bathroom Mirror - Lights not functioning in the UK Electrical Forum area at ElectriciansForums.net
LED Bathroom mirror was left on overnight and the LEDs now fail to illuminate. The mirror has a built in heater and this seems to still be working as is the on/off sensor. I have thought that maybe the LED converter (SLT15-24VF-1) has malfunctioned, but trying to source one of these I have found impossible.
Any thoughts?
Find your receipt and see what warranties you have! LED would not normally expire just for being left on.
The LED converter may have overheated and its over temperature protection has shut it down.
Leave the mirror turned off for a while to cool down and see if it resets.
Sorry, have I said something wrong here Archy? Yes, I have taken a while to get round to fixing it, which is humerous, but if you can't help me I'll buy a new one. Thanks for your help!!
Which is why some members of the general public dont like calling electricians .....FFS guys these are potential future clients.
As the OP asked the LED part not working what has RCD protection got to do with it. Ive said it before why be so cocky to potential customers and yes i do think the general public read the forum and what an impresion they must get from some members.
I wonder if the circuit has RCD protection?
I fit a lot of led lights in shop display lights, buy your self a 60w or 5a led driver off eBay for about 7 quid if it's the sort of mirror, heater, light, shaver type I'm thinking of you'll be able to remove the old and glue one of these in. Job done
I’m glad I’ve never had to deal with the public electrically.
Customer; “I’ve taken it to pieces, can you fix it?”
To be honest with you, I believe that the OP probably installed the mirror themselves.
Fairly certain, that if it had been installed by a tradesman, the OP would not have waited 6 months before asking for advice on a forum, but would have been straight on to the tradesman.
Hopefully, the OP will now be thinking "RDC what? I wonder what else I haven't done right? This time I'd better call an elecrician."
I recently got called to a cooker fault.
The customer had connected the cooker cable to the CCU, but had left so much slack cable in the back box that the neutral conductor was caught between the back box and a screw. fortunately the circuit was protected by an RCD.
I also have damaged one of the led strips in one of these, their only on pcb board and wired in series. Awkward trying to hold the mirror and plug heater element in, some how hot this caught round the LEDs.
Electric Will - Thanks for your reply that basically let me know that a LED converter is also called an LED driver, made finding what I need much easier. Took me 10 minutes to replace.
For those who felt the need to mock or presume, I hope you don't go into your customers properties with that attitude.
Reply to LED Bathroom Mirror - Lights not functioning in the UK Electrical Forum area at ElectriciansForums.net
Hi All I have recently had a new bathroom mirror installed with a built in LED and Demister that is turned on using a motion sensor. The mirror...
I have three Aurora Fluorescent linkable (linked) under cabinet 'strip' lights (c.21cm each) under the kitchen cabinets and over the sink area...
I am installing 9 LED downlights each with an RGB bulb in (i will try attach pictures on them) - anyway I have been told that they need to be...
Hi, I live in a property built in 1911. It has had asbestos artex applied to every ceiling in the house. I am currently creating a new...
