Advertisement - Content continues below
Discuss Led batten, one flickering. in the Lighting Forum area at ElectriciansForums.net
Put up three new led battens in the workshop and after a few weeks one of them is flickering.
They are all on the same circuit , single switch and no other problem lights in the house on same mcb.
Lighting is not currently rcd protected but cu is due for an upgrade. I'm training to be a fully qualified spark after being underwhelmed with the Electrical Trainee nonsense currently doing level 3. Any thoughts on what could be the cause of the flickering in that one fitting? Thanks in advance
Test Meter - Forum Sponsors since 2007!
telectrix
Mentor
try swapping the lamps/bulbs/tubes see if the fault moves.if it does that's the problem.
littlespark
Advent Win
Some LED batons are just LED strips inside. No tubes to change. You might just have a duff one.
Take it back and get a replacement.
littlespark
Advent Win
Inside the ones I’ve fitted, there will be a driver, and that’s about it.
If it started flickering a few weeks after install, money is on the driver.
Or loose connection? Even the factory made ones.
Charlie_
The budget range tend to have drivers that are undersized for continuous use.
Especially in commercial environments where the lights are on all day
  • #8
I will start with the least work and check my connections then if no joy swap the fittings then see what happens. Thanks pal
  • #9
Hi , interesting information that thanks. They were not particularly expensive at around 35 quid each but they are only in a home workshop and used infrequently.
static zap
Advent Win
( Good old fluorescent days ,No ceiling-if there-is no heating...Keep eye out for problem end near up-and-over-doors ..may be cold/condensation drips from roof !)
  • #11
It's stopped flickering......I was informed that whilst the light was flickering last time they hit it.... now I have switched it on and it's stopped.
CK Tools :) The professionals choice when it comes to Electrical Tools
Reply to Led batten, one flickering. in the Lighting Forum area at ElectriciansForums.net
Bulk Workwear - Clothing Suppliers for the Whole Forum Network
Top Bottom
