Discuss Led batten, one flickering. in the Lighting Forum area at ElectriciansForums.net
Put up three new led battens in the workshop and after a few weeks one of them is flickering.
They are all on the same circuit , single switch and no other problem lights in the house on same mcb.
Lighting is not currently rcd protected but cu is due for an upgrade. I'm training to be a fully qualified spark after being underwhelmed with the Electrical Trainee nonsense currently doing level 3. Any thoughts on what could be the cause of the flickering in that one fitting? Thanks in advance
The budget range tend to have drivers that are undersized for continuous use.
Especially in commercial environments where the lights are on all day
Reply to Led batten, one flickering. in the Lighting Forum area at ElectriciansForums.net
I am not an electrician but am looking for some advice as to how to fix my sporadic light flickering problem that has come and gone for the year...
Evening All, Strange one so after a bit of advice. Got called to a customer this evening who had their boiler repaired after the circuit board...
Hello, I’m boarding out my loft for storage and I’d like some decent lighting up there rather than loft lights I’m currently using. I purchased...
I have a issue with lights flickering in my home. Specifically led lights. I’ve bought a lot of brands of led lights and even most of the...
I'm trying to replace 4 inset downlights with surface mounted ones: Phoebe LED, Atlanta Universal Downlight 6.5W/3000K, chosen as they'll...
