Discuss LED batton connected to a fused plug in the Lighting Forum area at ElectriciansForums.net
nogger36
Hi ive bought an LED strip light to replace and ‘old fashioned’ one which is in my loft. The existing is wired via a fused plug to a socket in the loft the new light is double insulated and unlike the old one doesnt need an earth. Am i ok still connecting it to a fused plug with maybe a 3 amp fuse in and not have any earth? Im a DIY’er as im sure you can guess!
Short answer is yes that is fine.
If the cable you use has an earth in it, connect it at the plug and then cut it off at the light fitting.
Reply to LED batton connected to a fused plug in the Lighting Forum area at ElectriciansForums.net
Hi, I'm trying to rewire an old plug. I've rewired a few in my time, but all have been with the post-2006 wire colours. I have this old welder...
I have a baffling problem with a newly-installed PIR floodlight and I'd like advice from the forum as to whether it's defective (and should be...
BMS installers have attended. After fitting the panel they also replaced the aged lighting in the boiler room with 6ft LED battens as instructed...
Our family room is part of an addition built a few years ago. We had an issue with nuisance tripping on an AFCI and the electrician came and...
Hi all. Have an issue i'd love some advice on if anyone would be so kind. Will try to be brief. Thank you!! So, have an intermittent RCD trip at...
