I just finished painting a bedroom and replaced the LED lights that were previously to small for the recessed cans with bigger LED lights of the appropriate size. While painting I only had 2 of the 4 new LED lights installed plus another LED light of a different size and left the other one empty. Everything worked fine before i replaced lights and while I was painting with mismatched light bulbs...
I finish painting and because the new LED bulbs were sticking out too much I adjusted the wing nut on every can replaced the coil springs and installed the 4 LED bulbs together for the first time. I turn the lights on (dimmer) and all 4 lights are on limp mode and seem to have a small pulse almost like a slow heart beat not a flash per say but the light gets slightly brighter than retreats. I replace one of the new LED bulbs with a different brand LED bulb i think its called A19 or something its the standard round shaped not meant for recessed lighting and i turn the lights on and they work. I swap around the lights but I cant get all 4 new LED bulbs to work correctly. They wont work if there are 3 installed leaving one empty but will work if install 3 plus anothe random light. The problem does not reside with one particular bulb.
why?
why?
