Skip Ellis
- Reaction score
- 0
My kitchen has recessed fluorescent fixtures (36" T12's) in deep soffits around the ceiling . One group has (2) two lamp fixtures on a switch. The second group has (3) two lamp fixtures on a switch. The heat buildup over the years has ruined the plexi covers and caused the ballasts to drip tar. I'd like to convert the whole mess to single end LED T8s but am not sure how each set is wired. I've watched the conversion vids of a single fixture sitting on a bench and it's a piece of cake but trying to do these 'in place' is going to be a bear...so far, I haven't even been able to get the fixtures out but I'll succeed eventually....I hope. My question is: how do I wire these multiple fixtures? Do I run a hot and neutral to the power end of each tube in the first fixture, then jump from there to the power end of the second fixture? I'm assuming the hot leg of the switch is going to the first tube then jumping over to the second tube with the neutrals doing likewise. Help!!!!! Oh, and to make matters worse, each fixture is in it's own soffit/box with 2x framing between. If I could see it diagrammed out, I could probably get it but all those wires feeding the ballast is confusing me. Maybe I need to cut everything loose, find the hot lead and go from there?
