Discuss LED Downlight Connectors in the UK Electrical Forum area at ElectriciansForums.net
The standard choc block type connector is a pain to loop a couple of 1.5mm T & E cables into whilst ensuring no brown or blue insulation is showing outside of the connector. Downlighters such as the JCC have a very easy 6 terminal push fit connector which takes seconds to conect into.
So the JCC are more expensive to buy but cheaper to install - whats your problem?
Reply to LED Downlight Connectors in the UK Electrical Forum area at ElectriciansForums.net
Hi all, a very long time I did a swanky grand designs type new build in the middle of nowhere, so in the middle of nowhere that it's a house with...
Hi I have an electrician over and he took over from an incompetent builder. The builder already installed the wiring but the electrician told me...
Hi I wanted some advice regarding which downlights company is better from ancell or forum? I have builders doing works in my house but I wanted...
Hi all, I am about to fit a light fitting and wanted some advice whether I should just connect the light cables into the correct terminal blocks...
I am installing 9 LED downlights each with an RGB bulb in (i will try attach pictures on them) - anyway I have been told that they need to be...
