Discuss LED flasher unit in the Auto Electrician Forum area at ElectriciansForums.net
Marden
Hi. New member here. I have a strange problem with a new LED headlight installation on my very old VW. I've recently installed a set of ebay LED headlights and tail lights on my old buggy. They're the ones with an outer ring that swaps white/amber for the turn signal. They're running through an LED flasher unit and the problem I'm having is that they function fine when used by themselves, but when the outer ring is lit. the front will remain solid amber while the rear continues flashing. They're both on the same circuit running through the same flasher, so how on earth can one remain solid amber while the other continues flashing? It's driving me nuts, so any help would be greatly appreciated. Thanks in advance. Mark.
Hi,when you say negative bus,is it the circular ring,with multiple male Lucar spades?
It may be worth confirming it's full connection with the vehicles ground.
A diagram or link to the system wiring you have,may assist.
Reply to LED flasher unit in the Auto Electrician Forum area at ElectriciansForums.net
Hi all as mentioned I fitted two new stedi led indicators to my Suzuki 2018 drz400sm the front ones not stedi were fitted by the previous owner...
I have a baffling problem with a newly-installed PIR floodlight and I'd like advice from the forum as to whether it's defective (and should be...
I live in a flat in Scotland supplied with an old 2 meter system called THTC where one meter using a time signal supplied heating and hot water...
Sure this has been answered before, can’t find a specific answer though. My house was rewired in 2021 and as part of the rewire I had LED lights...
I really need help with this puzzler. First - I am moderately 'skilled' in day-to-day basic wiring. My puzzle: I am trying to replace a...
