Discuss Led lamp still glowing in the UK Electrical Forum area at ElectriciansForums.net
Good morning. I’m a apprentice electrician and I have done a job in my house changing a light. It’s a loop in system. I’ve put led G7 lamps in the new light however when I turn it off the lights still have a slight glow on them. I understand that this could die to leakage but is there anything else that it could be ? Any ideas on how to sort this will be greatly appreciated
Hi - if the the lamps glow it’s likely because there is a small voltage present, so a couple of quick checks maybe? Confirm the fitting is earthed and the polarity is correct to the switch and the light (no floating line voltage at the fitting when it’s off :) ). After that it’s adding a load (capacitor or a neon maybe) or changing lamps as mentioned already.
Sorted. One tested polarity and all good. No voltage between n+e and no voltage at light when off. Changed one of the lamps and problem solved. Must have been a faulty lamp !!! Very strange.
Thanks everyone for your help
Reply to Led lamp still glowing in the UK Electrical Forum area at ElectriciansForums.net
Hi. I’ve got two pendant lights that currently run halogen lamps. One of the converters is broken so I’m planning to change both for LED lamps...
Hello I have some decking lights which to be fair, have been nothing but pain in the bottom since they were installed. Moisture in the lens lamps...
Hello all- I hope this is the right place to ask this question. A few weeks ago the LED lights in the kitchen started flickering intermittently...
Hello I have recently moved home and I looking to upgrade lighting across the house to LED. In the kitchen I have found that there is installed...
I am trying to put some led light strips under the fenders of my fat tire E-bike. I’ve been looking at led light strips on Amazon, AliExpress and...
