Discuss LED LIGHTING in the UK Electrical Forum area at ElectriciansForums.net
Can anyone recommend LED lighting for a garage workshop. They have wall mounted HPS Floodlights at the moment & when the 3 phase compressor cuts in, most go out & restart after a while. I have fitted some LED ones in the past that they have supplied, which failed in 2years or less. I was thinking ufo LED units hanging on ceiling & other Floodlights adjustable angle on perimeter walls. Need to find a reliable solution.Any help with a brand name would be very helpful. Thanks in advance!
Looks like a VD problem Mate, maybe sort the wiring sizes out first before you go spending needlessly, on replacement fittings.
Yes that is what I told them, but because I had fitted 2 led floodlights in a w/shop near the main intake they are not affected by the voltage drop. They think LED lights are the way forward.
That's not really a solution to me just masking the problem. Id explain to them the real problem and proper solutions.
Reply to LED LIGHTING in the UK Electrical Forum area at ElectriciansForums.net
Hi All, Would be grateful for some advice. Would like to add an additional light (Undercabinet 8W LED Batten light) to a two-way light switch...
Hi guys I have some industrial lighting circuits to wire in a workshop and was after some fresh ideas/suggestions as to how i could best do this...
Hi we are replacing light fittings in our home. Im confident with the fitting aspect, but have run into doubt in making the right choice of...
Hi all, Great forum with lots of advice read and greatly received over the years! I have a question here that I am hopeful somebody here can...
Hi there, Please can I have some help with the following: I want to have some perimeter lighting in the ceiling which will be using the...
