E
eco-tech
Can you use LED MR16 lights in normal low voltage transformer ?
I have a pal who says yes but it will reduce the life time of the lamp. Is this the case ?
don't these LED lamps need drivers?
Should really be on a LED driver depending upon which way they are wired it can be either constant current or constant voltage typedriver.
LED Lighting
eco-tech,
ian.settle1,
