Discuss LED Lights flickering, Harmonics Issue? in the Electrical Forum area at ElectriciansForums.net
First post on here, but i'm honesty at my wits end! I installed four Lutron in-line dimmers about 9 months ago, all on the same new lighting circuit. Last week the client rang to say that there had been a power cut locally, and when the power was restored, all his Lutron dimmed circuits were flickering, badly.
I attended today, and they are flickering, and this is worse when dimmed. I broke the circuit down and it's good. I checked the supply characteristics and they're good. I changed the main switch and RCBO and they're good. With all other circuits in the house, all the connected dimmed loads flicker.
Finally, I made a test rig with one of the affected dimmers and placed this on a plug top. It still flickers on any socket circuit. The next door neighbour even kindly allowed us to try his sockets, and it still flickers.
I took it home to mine and it's perfect. I tried it in an property on the next street along, and it's perfect smooth dimming.
I spoke to the manufacturer an the NICEIC and they both said speak to the DNO, possible harmonics issue.
The DNO have just been out, done and EFL test and said nothing more they can do or check! The client mentioned possible harmonics issue, but the DNO lad said the supply was good.
The loads are 2 circuits of 10 x 10w 350ma LED lamps (Trailing edge dimmable), 1 x 30w 12v LED driver, and 1 x 10W LED Pendant lamp, all have been working flawlessly up until this power cut. I immediately thought they must have been damaged by a surge, but I can prove they're good at my property and others!?!
Any advice on where to go from here would be massively appreciated.
Thanks in advance.
marconi
Mentor
You have your own and the clients testimony that all was well before the power cut but not subsequently nor with the neighbours supply. The dimmers work fine in your remote home And in a nearby street. You could buy one new Lurton and try at the client’s and then your own home to show the problem is indeed supply related. Then you can take the dno behind the bike sheds and discuss their initial response, it would have been more believable to blame covid. Tell them to earn their supply service charge.
Lucien Nunes
Mentor
Welcome aboard @anthonini and thanks for your clearly explained and detailed first post.
Yes, harmonic content i.e. distortion on the mains could easily be a factor. But the question is how much distortion is too much As I was only saying the other day, some combinations of dimmer and LED are only stable under ideal conditions. As soon as the supply varies a little, some nuisance behaviour shows up like flickering or interaction between dimmers. Perhaps after the outage that supply was transferred to a different transformer, or the same transformer on a different tap, and the voltage has changed. Or there is a bit more 3f on this supply, or whatever.
The headache now is that the supply might still technically be within spec, but not quite good enough for a marginal setup of dimmer and driver. Although the dimmers had worked fine after installation, they had probably never been subjected to a wide range of legitimate supply variations.
Please keep us updated with your findings.
marconi
Mentor
You might want to:
1. Compare how many electric vehicle charging points there are in the client's street with the neighbouring street and your own street. Does the client have an EV CP?
2. Does the flickering occur at all times or when it is likely that electric vehicles are being charged in the evening and overnight, so the problem does not exist during the day.
3. Is it an old overhead line with a reduced thickness neutral as compare with the line conductors.
4. Is the sub-station 'far away'?
5. Is there electric heating in the home and in this road?
Background: Non-linear loads such as big battery chargers which rectify and then smooth the incoming ac produce harmonics, the most troublesome generally being the third because instead of the out of balance third harmonic phase currents adding to tend to cancel out, they add up. This large third harmonic neutral current can be 3 times the phase current - see diagram. This current will cause a third harmonic voltage drop along the neutral which will/might/could interfer with devices which like a dimmer which rely on switching on and off depending on the point in the voltage/current waveform. Dimmers are designed/assume the waveform is sinusiodal at 50Hz. The supply transformer itself can start to produce harmonics when it becomes heavily loaded because it enters non-linear regions of the B-H curve eg: if starts to saturate - remembering this happens for 50Hz current and its harmonics. You get the gist......Such knowledge may help you 'push back' on the DNO.
    You don't have permission to view attachments. Attachments are hidden.
Reply to LED Lights flickering, Harmonics Issue? in the Electrical Forum area at ElectriciansForums.net
M
Hi, I have American tenants who use transformers. When they do, the lounge spotlights and kitchen light flickers. These are on dimmers. Can something be done about it?? TIA!!
Lucien Nunes
Lucien Nunes
Z
We have two units (with separate meters and panels) in a residence that underwent a major renovation about two years ago. During the renovation, the HVAC system was replaced and new recessed lights and light fixtures were installed throughout. This summer, when the AC compressors are running...
zerofloors
Z
G
I have some really nice vintage type LED bulbs on some dimmer sockets I installed on several of my lights. The problem is they flicker, switch on and off when dimmed. Seems like there would be a lot of these sockets, but I can not find them anywhere. Amazon for example has a bunch of these...
littlespark
littlespark
C
Hi all. I have a few issues: - I bought an LED spotlight which is 50w (Input power 7.8w) 240v, but it flickers when I turn the lights on. There are 2 other older bulbs in the circuit which are 12v 20w..... When I take these other two out and just leave the new 50w LED bulb in it still flickers...
telectrix
telectrix
I installed 2 LED bulbs into my Genie garage door opener and it caused the microwave to lose power. They are both on the same circuit. When I tested the voltage at the microwave outlet it read 48 volts. That usually means a ground reference problem. Take the bulbs out and the microwave lights up...
Lucien Nunes
Lucien Nunes
Electrical News from Electricians Forums and Friends
E
Want to become a qualified electrician? Look carefully at the training courses on offer to avoid wasting time and money, is the advice in a new campaign from electrical industry body The Electrotechnical Skills Partnership (TESP). With thousands of searches each year on terms such as...
6K
Marty92
Dan
You can now link your account with social media by going to the following page. https://www.electriciansforums.net/account/connected-accounts/ We had this feature some time ago but I removed it when Facebook was found to be selling the data they collected without informing the users of what...
Dan
Dan
There was a dodgy advert, typical clickbait, showing "how to save 90% on your electricity bill" which was not the case and it was actually showing some dangerous wiring tactics. Read the actual threads here:- What should be the code for this - C2 or C3 -...
8K
Jurassic Sparks
Jurassic Sparks
James
The Go Plus hot tub is being recalled because you could get electrocuted taking a dip, according to press releases from the Chartered Trading Standards Institute (CTSI). An Amazon spokesperson said: "Safety is a top priority at Amazon. "We require all products offered in our store to comply...
Dave Appleby
Dan
Posted on behalf of @CKI:C.K-Tools Carl Kammerling International Ltd, also known to as ‘CKI’, are the company behind the C.K Tools brand. Founded in Germany in 1904 and with roots stretching back to 1790, we provide a wide range of hand tools, tool storage, power tool accessories and...
4K
telectrix
telectrix
Search Forum
