Discuss LED lux meter in the Electrical Tools and Products area at ElectriciansForums.net
G
Guest 004
Hi peeps
I need an LED lux meter that can measure the full spectrum of light emitted. Any recommendations.
I also need to convince the 'buyer' and engineer as to why normal meters don't work.
Good solid advice please, with some links?
What's the disagreement about? A decent spectrum analyzer will cost a few thousand pounds, it's the kind of equipment you'd rent rather than buy.
I just to measure emergency lighting lux levels.
We was getting a reading of 0, when there was sufficient light levels with the life safety equipment.
A lux meter measures visible light, which even an led wavelength covers. The only time leds lights give false readings on lux meters, is when they are dimmed or driven using PWM. Being switch on 100`s of times per second, can through the meter out. But never seen one showing zero...?
A spectrum 256k colour lux meter is a bit expensive just to prove a point. Sounds like you need a new meter, so maybe this is more affordable..Extech LT40 LED Light Meter
i was having problems with my old meter and found out that the old type of photodiode are only calibrated to tungsten filament wavelengths 3000k and can give false readings from led panels because they are on the bluer side of the spectrum:
5000k+
Reply to LED lux meter in the Electrical Tools and Products area at ElectriciansForums.net
Hi all, Great forum with lots of advice read and greatly received over the years! I have a question here that I am hopeful somebody here can...
Hi all, H.N.Y. The passive, affixed to a recently bought LED security light is rubbish, sometimes it works, mostly it doesn't, no matter how...
Hi All, Would be grateful for some advice. Would like to add an additional light (Undercabinet 8W LED Batten light) to a two-way light switch...
hello. I'm using leakage clamp meter to investigate nuisance tripping in my house. It is a MULTICOMP PRO MP780050 that I bought early 2021...
