- Reaction score
- 3
Discuss Led panels in false ceilings in the Lighting Forum area at ElectriciansForums.net
Highly unlikely that ceiling is a fire barrier so no.
Suspended ceilings can be fire barriers but they have to be certified. It is highly unlikely that these exist in your school.
Fire rated suspended ceilings are quite rare. The norm in your suggestion is to fire proof the upper ceiling. Fire rated suspended ceilings are expensive and have to be certified and correctly maintained.Usualy if the ceiling is below a timber mezzanine floor, and the underside is not plasterboarded, it may class as 1/2hour fire rated.
In this case the fittings should have hoods,and all the tiles should have clips holding them in.
Genuinely intrigued by this. I understand having some kind of "hood" over light fittings to prevent the lights setting fire to insulation above, which is not such a problem with LED fittings as they don't get too hot, but if a plasterboard ceiling has light fittings installed as illustrated, is a hood necessary to maintain some level of fire-proofing in case the fire spreads from below? Is this only needed if the ceiling in question is being treated as a fire barrier?
See above @westward10 he is the man for this kind of thing. Ok take it back about the pattresses.why?
Reply to Led panels in false ceilings in the Lighting Forum area at ElectriciansForums.net
