Discuss LED Spiral wall lights in the The Welcome Forum area at ElectriciansForums.net
Hi everyone. I’m new here. If anyone can help me; I’d be very grateful. How do I fit these lamps to a ceiling rose? As you can see, the two wires coming from the lamp are the same colour.
Have you got the screw on base for it. I'll be honest I would not consider putting anything like that up in my property I suspect it is of dubious quality.
It doesn't fit to the ceiling rose that needs removing. The base plate screws to the ceiling then the fittings screws onto that. You then need an electrician to correctly connect it in the ceiling void.
That tiny box I believe is the driver. I know what I would do with it.
Reply to LED Spiral wall lights in the The Welcome Forum area at ElectriciansForums.net
Hi, Can anyone please advise on what LED recessed lights to buy and how to wire for media wall 👍
Hi All, Would be grateful for some advice. Would like to add an additional light (Undercabinet 8W LED Batten light) to a two-way light switch...
Hi, I am restoring an old art deco, wall mount medicine cabinet. The cabinet has an 18” fluorescent light tube on each side. Before I put a lot...
I've been asked by a client to 'mask off' the green LED charging indictor lamps within several emergency lights fitted within bedrooms on a...
Hi all, I am planning to install wall lights such as these ones (LAP Bronx Outdoor Up & Down Wall Light Black - Screwfix -...
