Discuss led stays light in the UK Electrical Forum area at ElectriciansForums.net
G
garyboy632
hello am new to the site.
working in the hotel industry and have change all hallogens lamps to led,but in one of the circuits i have 10 led lamps and when the switch is on the off position 1 of the led lamps stays alight and i am getting 20 volts through the circuit.
any ideas is it possible to have a shared neutral on this circuit and why is only one led lamp staying light when off
Sounds like induced voltage from other circuits. You need a Snubber you lucky person!!!
Short term fix is to put back one halogen into the circuit which should help dissipate the induced current.
maybe use that neon tester that came with the set of VDE drivers.
just tell the customer that it's an emergency light. :grin::6:
try changing the switch, that sometimes works!
Get real, Kath. How could it possibly be that?
If it were the switch surely it would affect all of the lights.
Reply to led stays light in the UK Electrical Forum area at ElectriciansForums.net
Hi All, Would be grateful for some advice. Would like to add an additional light (Undercabinet 8W LED Batten light) to a two-way light switch...
Suggestions / solutions please anyone? I have a 2 way switch, Hall and Landing, power being fed on Landing. When the switch is turned on, the...
Why is this still a thing, just done a quick calculation with the TLC volt drop calculator and if its a non lighting circuit the recommended size...
Hello I have some decking lights which to be fair, have been nothing but pain in the bottom since they were installed. Moisture in the lens lamps...
Hi guys I have some industrial lighting circuits to wire in a workshop and was after some fresh ideas/suggestions as to how i could best do this...
