Discuss LED Strip RGBW - How to split for parallel wiring? in the Lighting Forum area at ElectriciansForums.net
Pandaman
I'm looking to install some LED lighting strips to light some display shelving.
It will consist of one driver going to a controller which will then be split into 8 x 1m length strips.
I was wondering if anyone can give me an idea on how to split the power from the controller to each strip i.e. which connectors/junction boxes.
Are the 8 x 1M strips end to end or is there a distance between them?
Not end to end. Driver and controller to be fairly central in my shelving cabinet, then 8 individual strips to be powered. They are all pretty much equal distance from the controller.
Are the led strips pre wired with a length of cable? As LED strips are normally all connected in parallel from a constant voltage driver then all you need is a cable from the controller to a junction box. From the junction box connect the cables from the led strips using wagos and matching the core colours eg. red to red etc. If you need more than 1 junction box then join together using the same method.
The strips will not be pre-wired as I would need to cut from a reel and make the wire connections.
I was thinking about using Wago connectors, I have used 222 Wago in the past but they are only 3 way and wasnt sure sure to split it 8 ways. I assume the purpose of the junction box (i.e. wagobox) is just to house all the Wago connectors and they can be daisy chained off for additional connections?
Reply to LED Strip RGBW - How to split for parallel wiring? in the Lighting Forum area at ElectriciansForums.net
I've fitted some led lights with power supply and mi light controller, they were working fine and all colours could be seen, then for some reason...
First time poster here seeking a little advice/confirmation I have spurred off to a fused switch and from there running two 2.5mm cables to the...
I am currently looking to add 12v led cob strip lights to my mother's kitchen but confused what I need. There are currently mains wires under the...
We are in the process of renovating our house, and would like to setup led strip-lighting throughout. of the options, this seems most attractive...
Hi there, Please can I have some help with the following: I want to have some perimeter lighting in the ceiling which will be using the...
