Discuss LED striplights wired to ring main in the The Welcome Forum area at ElectriciansForums.net
Hello all,
I'm new here, first post and no elec qualifications, so a few condescending replies I'm sure are more than deserved.
I'm currently looking to add some strip lighting to the back of some shelves in the bathroom (wife thinks it looks fancy). What I really want to do is avoid a second switch. I just want them to turn on and off with the main lights.
Only problem is I have a dimmer switch controlling the bathroom lights, and I don't want the strip lights to dim with the main lights.
My question is: assuming the dimmer has ample wattage to deal with the extra load, will enough voltage be supplies to the transformer if the dimmer switch is used to maintain a consistent brightness to the striplights?
Also is there something glaring problem or solution I haven't considered with this which is obvious to you?
Thanks for taking the time to read everyone, much appreciated, and apologies if I have posted in the wrong place or not tagged it correctly.
If the driver/transformer for the LEDs is dimmable, you can potentially connect it to the dimmer but the strip lights will dim accordingly. If it is not then they won't be happy partners and you shouldn't connect them together.
A second switch is possibly the best option or just swap the dimmer out for a switch and do away with your mood lighting!
There are special considerations and regulations around electrical work in bathrooms so it's probably best to get an electrician involved in this.
Hello all,
Sounds like you should call an electrician
Reply to LED striplights wired to ring main in the The Welcome Forum area at ElectriciansForums.net
Hi :) I'm currently renovating my outbuilding. My electrician has fitted 10 conduit LEDs (that support both leading and trailing edge) and x4...
I am currently looking to add 12v led cob strip lights to my mother's kitchen but confused what I need. There are currently mains wires under the...
our dimmer switch stopped working after 7 years so went to replace it at the weekend. When I opened it up, the black wire was in the common slot...
I have a led panel that i want to dim. It is dimmable but without a dimmable driver. I have a dimmer module and a dimmer switch as shown in the...
I was at a customers house changing a socket and they asked me a question about their lights. Some of the lights in the house suddenly get...
