I've purchased Lepro 15m LED strip lights - product code PR410047-RGB-UK, and have fitted them at the top of the walls in my daughter's bedroom, where the walls meet the ceiling. Although listed as 15m long, they are actually two strips of 7.5m each, running in parallel adjacent to each other up the corner (about 1m distance) to the top of the corner wall/ceiling interface, and then each strip goes off in the opposite direction to go around the whole room. They are powered from the supplied adaptor plugged into a standard UK wall socket, and there's a small control box with a receiver on it that both strips of lights plug into. It's all supplied as part of the package.
I've found that the strip lights don't turn off properly. When you select 'off' on the remote, it looks like they turn off, but actually they're not off, they still emit a fainter pale whitish light that is easily noticeable at night or in a darkened room. So they're clearly still 'on' to some degree and drawing power. The only way to switch them truly 'off' is to switch off at the power socket on the wall, only then do they really switch off and go completely dark.
When I discovered this, I took the lights down and replaced them with a second identical Lepro set, having tested the second set quickly in the dark to make sure that they did indeed turn off properly. All was good in the test, so I've put them up on the wall around the room............only to find that they too now don't turn off properly. It's exactly the same issue as the first set of lights. Swapping the control box, power adapter and wall socket they're plugged in to makes no difference, they still don't turn off properly unless switched off at the power switch. But they tested ok when not fitted around the room. And similarly, the first set of lights I've taken down now tests ok now that they're no longer fitted around the room.
So, bizarre as it seems, it looks like it's something to do with the location of strips. When not fitted at the top of the wall, and tested in the dark simply laid on the bed, they do go properly off with the remote. But fitted around the top of the walls around the room, they don't properly go off with the remote.
There are no power wires around the top of the room, only a central ceiling light. As it's a relatively recent house (20 years old) the plasterboard for the walls is fitted to a metal framework, and although I can vaguely recall stuff from school about moving magnets in a coil generating electrical current etc there's nothing like that going on here that I can work out !
So I'm baffled.......part of me thinks the answer must be obvious, but I'm not seeing it.........would appreciate any advice and guidance, thank you.
