I just rewired my kitchen CFL T8 fixture with direct wire - double ended Sylvania A/B type LED tubes, no more ballast. One single 120V 15A line connected to living room with LED dimmer and LED light bulbs. Couple of the feet from dimmer another simple On/Off switch(kitchen) connected to the same AC line and T8 LED tubes fixture as described above. When living room dimmer set to low setting - kitchen tubes won't turn on sometimes. When i increase the living room dimmer brightest the kitchen tubes will come on instantly. This happens intermittently like 50%/50%. LED dimmer brand new and designed for LED's. Any ideas why?
