Discuss LEDs in the Australia area at ElectriciansForums.net
telectrix
Mentor
just found these----------- (GU10 fitting) 12 LED, 1watt GE LED lamps, quite a good light for what they are, £4 a pop from Asda
Asda... only time will tell if their any good I suppose. Cheap though. Bit like when CF first came out expensive in the wholesalers but always a nice cheap alternative in the supermarkets
yep, but they are GE, General Electric, should be ok
in the store, but electric center do 2w for just a bit more, but if u go asda, make sure it's LED in the box. some crafty customers are swapping the boxes for GU10 so they get a £4 LED for the 99p cost of a GU10
Reply to LEDs in the Australia area at ElectriciansForums.net
Hi I currently have 4 led bulbs in the bathroom and 3 of them arent working. The bulbs that are currently in are LOMAS LED GU10 220-240V 6000k 6w...
Hi we are replacing light fittings in our home. Im confident with the fitting aspect, but have run into doubt in making the right choice of...
I am currently looking to add 12v led cob strip lights to my mother's kitchen but confused what I need. There are currently mains wires under the...
Hello all- I hope this is the right place to ask this question. A few weeks ago the LED lights in the kitchen started flickering intermittently...
I have two 4 inch recessed CLF 4 pin light cans installed in laundry room since 2012. The bulbs are fluctuating in brightness. I think the...
