Discuss Let’s hope the boiler don’t leak then.... in the UK Electrical Forum area at ElectriciansForums.net
If it was ever effected by a leak, anyone touching that socket with one hand will quite possibly have their other hand on the earthed copper pipes for support - making their arms, and the beating heart between them a bridge between live and earth :eek:
On the other hand, if it's on an RCD it's a pretty neat leak detection system :)
Nope no such luxuries as rcds, old wylex rewireable fuse board,only 3 circuits on it...
The earlier bakelite ones? Not sure if you know, but they actually did design MCBs that would plug into the original fuse bridge for those. Maybe do some research and go back and upgrade the old beast and slap an inline RCD between the main breaker and the circuits, you might just save a life one day!
Or at very least go back and install an RCD at high level above those aquatic sockets they have :)
All joking aside, the biggest danger is actually fire. The thing is, most leaks are typically tiny, and almost impossible to see dribbling down a wall in a dimly lit space. If such a dribble runs behind the face plate and over the contacts it erodes the contacts at an accelerated rate - within days a clean contact can oxidise to the point of being a blunt lump of rust, which will generate huge localised heat without breaking the fused connection.
And that's when water and electricity causes a fire. Conversely whilst the presence of water does greatly increase the chance of you getting a shock, it hardly ever leads to serious injury or fatality as water is actually a really, really appalling conductor. It also has the habit of running downwards and is already finding better paths to earth than you could likely offer by sticking your finger in its path. The truth about water and electricity is that it's dangerous not because it conducts, but because it can go anywhere. I've made a career and living out of containing water safely in the most awkward of spaces, and I hate the bloody stuff!!
Thanks deuce, yes seen the plug-in mcbs, I have advised the Home owner on a couple of options, that boiler was only installed 7 months ago!
Reply to Let’s hope the boiler don’t leak then.... in the UK Electrical Forum area at ElectriciansForums.net
Just looking at my boiler wiring out of interest, and just wondering if it's wired correctly. So perma lives, neutrals and earths in the right...
5K
My company has recently done some air source heatpumps which require DNO notification and EV chargers which also require DNO notification. On an...
Hi all, There's 2 single fan ovens in the house my mother recently moved into. Posh elecronic AEG units. It's been sat empty for a year, so the...
Hi, would would be your thoughts on this one? On the floor under the sink in my kitchen is a power cord that connects the small undersink water...
I'm writing this mainly hoping something occurs to me while writing it! I got called to an occasionally tripping RCD. It's a Hager double height...
