Discuss Lighitng Fault - lights go off but then come back on without tripping in the Australia area at ElectriciansForums.net
C
cside
Hi can anyone help me with this, basically this was happening before i changed the consumer unit (it had an old push in cartridge one before with a 13 amp fuse in it) and i have installed two lighting circuts instead of the original 1 which had 11 lights on it and was fed off a 1mm with joints everywhere. i am sure i have seen this problem on here somewhere before but cannot find the possible soultion so i went ahead and did this in the hope this would stop the possible volatge drop if it is that:D
Any wise old heads have any other ideas as to what i might be if the fault re apperas?
Reply to Lighitng Fault - lights go off but then come back on without tripping in the Australia area at ElectriciansForums.net
Hi all. We have a 120v 20 amp circuit to an accessory dwelling with a run of about 75' of direct bury #12. The breaker keeps tripping even when...
I have an issue with a home lighting circuit 6A RCBO provides power to 13 bulbs which randomly keeps tripping, when I say randomly it keeps...
Hi I know I have to do more testing but I just want to see if there is something I’m missing. Customer said light fitting in the loft was...
I'm writing this mainly hoping something occurs to me while writing it! I got called to an occasionally tripping RCD. It's a Hager double height...
I'm not sure what's going on with my kitchen light. I've replaced an old 28W CFL fitting with a new 4 x LED GU10 fitting (a cheap one from...
