Discuss Light and socket in the UK Electrical Forum area at ElectriciansForums.net
just a quick question can I power my outside light from the inside lights direct or do I need to take the feed from the inside to a switched fcu then to the outside. Same question for a outside socket also thanks
You can take a radial off the downstairs ring, into a SFCU (this protects thr cable and gives a local point of isolation if water gets in the fittings), same for an outdoor socket; radial off the ring into a SFCU then on to your socket/light fixture (choose as you want)
Personally I would keep the porch light to a lighting circuit however ensure the circuit has 30ma rcd protection. The socket can be connected direct to the ring final circuit but it needs verifying the socket you connect from is incorporated into the ring final and not a spur itself, again check for 30ma rcd protection.
Sorry to be pedantic, but as your profile says “trainee”…
A single cable from a ring final is a spur.
A radial circuit is a complete circuit from a consumer unit etc, that comprises of a single cable.
Reply to Light and socket in the UK Electrical Forum area at ElectriciansForums.net
Hi. Has anyone ever taking a feed from an outside light to use as a spur to fit an outside plug to plug in a plug in ring camera. The only feed...
Hi, Heavy industrial spark here, never do house bashing hence the question. I currently have a light switch at the front door not doing anything...
Hi all, Thank you in advance... So I had an electrician put in some FCUs on spurs to a couple of outside lights.. this one was in readiness to...
So a few months back I fitted an outside socket , the customer has messaged me saying it doesn’t work and I need to come and fix it etc. do I...
I bought this house a couple months ago. It was built in 1952 (same as me) but has been rewired with yellow 12 awg Romex dated 2007. Looks like a...
