Discuss Light bulbs in the UK Electrical Forum area at ElectriciansForums.net
Charlie_
Hoping for a big crop come harvest time
Hate to have to tell you mate, but that lamp is not going to work just plugging it into the ground like that. True you have your earth and I can see where you are going with it but you will need a line and neutral. Sorry to break it to you.
The area I have planted it in is prone to lightning strikes..
I was hoping this might be a new way to lead customers up the garden path on a stormy night. :) kerrrrrching!
There was a painter on one of the sites I worked on let's just say he must have been smelling the turps (or it might be he came from Brum) but as I put the GLS lamps in a compleated house he took them out and put them in the ground.
well sod you and your light bulbs. this year i'm planting heavy bulbs.
50302
I found out(from this site I believe) that there is no such thing as a Bulb
quote
For years, it has been believed that electric bulbs emit light, but recent information has proven otherwise. Electric bulbs don't emit light; they suck dark. Thus, we call these bulbs Dark-Suckers.
Proof is here
Bulbs
....... it has been believed that electric bulbs emit light, but recent information has proven otherwise. Electric bulbs don't emit light; they suck dark. Thus, we call these bulbs Dark-Suckers.
Just what scientists need proof that ,The missing dark matter was consumed by Nuc powered Generators ,munching on it.;)
Reply to Light bulbs in the UK Electrical Forum area at ElectriciansForums.net
I have a street light circuit on land I rent out. I need to replace 2 of the bulbs. 1 of them is an old Philips 55W SOX Plus, the other is a...
I've used light bulbs for freeze protection for lot's of things. Now incandescent bulbs are against the law. What can I use as a substitute?
Two questions: 1. I’ve had a bulb in the hall turn black with some white powdery deposits (see photo), whats caused this, guessing i should get...
I have a bulb that causes the fuse to trip. Had it for a couple of years, make is Diall. Maybe it's dead now, but I don't understand why it trips...
Hi we are replacing light fittings in our home. Im confident with the fitting aspect, but have run into doubt in making the right choice of...
