Discuss Light Switch Locators in the UK Electrical Forum area at ElectriciansForums.net
SKY
Doing some work in an old ladies house and she has asked for illuminated light switch locators at the top and bottom of the stairs as well as other key rooms in the house.
I normally use the MK ones which give a light green colour around the swich but I cannot use them this time as the lady has energy saving JCC LED downlights fitted and not standard incandescent lamps in most rooms.
Are there any plate locators available that can be used with energy saving lamps?
Cheers
Some illuminated switches actually use the live and CPC for the small current required, this would be fine for any type of lighting.
*Hard hat on*
have you tried the mk ones? araik, thy work off the l and the floating s/l.
If they use the switched live they'll probably make CFL's and LED's flicker or flash.
maybe not, but a trip wire at top of the stairs would. :lipsrsealed2:
Cheers
You can buy light switch surrounds which are fluorescent coated and they shine up in the dark and use no power at all
haven't had this problem my self but perhaps if connecting across phase and earth is not acceptable Adding a suppressor across switch line and neutral may help
Reply to Light Switch Locators in the UK Electrical Forum area at ElectriciansForums.net
Hi I am trying to replace my old white light switches for nice chrome ones but the wires are all red but the new switch has only l1 l2 top and...
Hi, Heavy industrial spark here, never do house bashing hence the question. I currently have a light switch at the front door not doing anything...
Hi I want to add a light to my attic. There is a single switch on the landing that I want to change to a double switch and then use it to still...
I have a rocker type light switch the sticks out bit too far and interferes with a drawer, as in the picture. The switch seems properly installed...
