- Reaction score
- 0
Hi all,
What would you code a light switch that has no box whatsoever? it literally is stuck to the surface of the wall. It seems that it was once installed correctly but then the owners insulated the house with celotex and a plaster skim and instead of cutting in a new box they just pulled the wires through the celotex and stuck the switch to the surface using expanding foam and/or whatever else they could find.
What reg would it be contravening.
Thanks in advance
Thanks in advance
