Discuss Light switch in the DIY Electrical Advice area at ElectriciansForums.net
Dave87
Hi
This is a bit for my OCD, the landing light works fine via both switches but when the light switches don't lie flush when the light is turned off if that makes sense? I have tried turning off the electrics and flicking the switch but it never work so its almost like the wires are the other way round?
Any ideas where I could start with this?
Do you mean it's in the traditional 'off' position but the light is on? Have a think about how the two way switching works.
The way that 2 ways work you can have the scenario:
Both switches off - light off
Both switches on - light off
Either switch on, the other off - light on.
or the other way
Both on or both off - light on
One on, one off - light off
personally, I prefer the first method; all switches are off means the lights are off.
And my OCD makes me turn my kitchen switches off to match a 3rd switch on the same plate, even if that means turning the lights on and off again to get the correct configuration.
Reply to Light switch in the DIY Electrical Advice area at ElectriciansForums.net
Hi guys. I will start by apologizing for the elementary question. I'm sure you get them often. The chandelier is in a hallway controlled by a...
Hi everyone, after temporary removing a Sonoff that I've installed years ago to do some painting, I'm unable to get everything back to work. I've...
Hi I replaced a Flash immersion timer with an apt one today and it seemed straightforward but just wondering should the light on isolation switch...
Hi there, I have an outside light that is turned on with a switch from inside and would like to change it to a PIR version incorporating an...
