Discuss Lighting a Tennis Court in the UK Electrical Forum area at ElectriciansForums.net
how do i account for voltage losses raising the current draw?
The maximum permissible voltage drop is a small fraction of the supply voltage. We used to say 3% for lighting to maintain the efficiency of filament lamps but with electronic LED drivers that could be relaxed somewhat, as the internal regulation maintains the light output and the efficiency of the fixtures themselves is nearly constant over modest voltage variations. But too high a voltage drop can cause the drivers to malfunction, and it also represents wasted energy (as heat) that appears on the electricity bill. Therefore it makes sense to limit it to say 5-6%, or perhaps 10% at the very worst.
For constant power, the current is inversely proportional to the voltage, so if the absolute worst case is 10% drop, then likewise the absolute worst case is 10% current increase. It's an approximation but there are too many contributing variables involved, including cable temperature, driver efficiency curve, etc, to be worth refining the maths at all.
Can someone explain where the 10A comes from, please...?
That would be my fault - rounding up 1800W to be 10A for the sake of easier maths in this thread. The real figure would be around 8.7ish
Reply to Lighting a Tennis Court in the UK Electrical Forum area at ElectriciansForums.net
Good afternoon all, I have been asked to quote for an LED lighting upgrade to 2 x outdoor tennis courts. The existing metal halide lights are...
Looking for some cabling advice for my garden project. I’ve put together this diagram below, which hopefully explains what I’m trying to achieve...
Hello, I live in Mexico, where I have a small, un-official trailer park on my property. The property is serviced by my privately owned, 650amp...
Hi. First up, I am not a qualified electrician so this is a DIY project However, I am physicist by training with a specialism in...
8K
Any you guys got any tips. The court is surrounded by metal fence,approx 6 led column lights,will be fed with existing Swa. Main bonding,tt system??
