Discuss Lighting and power to a new motorcycle workshop trackday business. in the UK Electrical Forum area at ElectriciansForums.net
Soulsurfer
Hey all,
Got to estimate out an install for a friend who's got a high roof shed/workshop and all power is fine and easy enough to sort but as far as lighting for the centre of the shed and / or around perimeter I need to look at best way to go with it fittings wise.
In the centre there will be two hydraulic lifts for bikes where most of the mechanical action will need higher quality light but trying to keep cost decent too. Roof fixing would be via jack chains or similar as has the kind of steel cladding type beams with the hooked bottom channel that Walraven etc.. do clips to fit or threaded rod kind of affair, other thing was thinking was tray between ends of shed where there are mezzanine floors and fixing led non corrosive batten fittings to underside of it.
My client and mate was thinking led floods each end facing down lengthways along shed but I'm thinking that could be a bit blinding if you're walking along either way.
Oh and there is one existing 250W high pressure sodium E40 fitting in there already but not sure it's worth using it ? Prob 5 mins plus start up too ?
Any ideas appreciated.
I would be thinking low or high bay lighting, they do not tend to extend sideways much and so will limit blinding on approach.
Normally around the edges strip fluorescents are common and cheap.
The HPS light is probably the most energy efficient light you can get so if the workshop is used for long periods it is well worth keeping.
Reply to Lighting and power to a new motorcycle workshop trackday business. in the UK Electrical Forum area at ElectriciansForums.net
I have a question for you all, We recently moved, and the old house had the analog meter on it, the new place has 3 structures on the property.. a...
Hi all, DIY here :) First off let me just say it is advice I am after as I am fully aware that I will probably need an electrician to complete the...
Hi All, I've posted on here before about this, that time i was asking what people thought about phase converters as at that point i thought i...
I would be grateful if some of you could assist me with selecting appropriate lighting. Yes, it's for this Men's Shed again, sorry... Basically, I...
My view on life, in any field, is not to produce more but to consume less. Everybody told me this is a very eccentric weird mentality. Perhaps...
