Discuss Lighting circuits query in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Lets have a bit more, what job? what exactly is the total load? how big is the existing cable? is all lights likely to be on at the same time at all?If a 6a domestic lighting circuit had say at least 30 lights on it , including lots of 50w gu10 bulbs what code if any would you put on a eicr?
Unless it's 1ml then it's overloaded I believe
So if a circuit is really overloaded but has the correct mcb then you don't mention it on EICR ?
Reply to Lighting circuits query in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
