Discuss Lighting Ciruits in Bathrooms in the Industrial Electricians' Talk area at ElectriciansForums.net
R
robert.e
Hi,
I am looking for sugestions to comply with 17th ed. when making alterations to circuits (eg lighting) in bathrooms. We now have to have these rcd protected. If its a BS3036 fuse box what would be a good way to provide rcd protection for the lighting circuit.
New box hehehehehe, or fit rcd spur outside bathroom and make sure all lights are fed via this, remember only the work you do has to comply, so if its a new circuit it all has to comply, if its extension or alteration then that has to comply, just make sure you detail on cert what work is covered.
Reply to Lighting Ciruits in Bathrooms in the Industrial Electricians' Talk area at ElectriciansForums.net
I put some news lights in a bathroom and new extractor fan. Did the tests and filled out form. A couple of days later another electrician came in...
Good day. First time poster. We recently had an electrician perform the EICR, as this is a newly purchased property I thought'd I would have the...
Hi, Just looking for some advice. In a bedroom there are 5 downlights on a dimmer switch. When turned on, every now and again these lights can...
As I've mainly done site work and moved into domestic recently, I'm a bit rusty on stuff like this, but if I'm adding a loft PIV unit to an...
