Discuss lighting fault? in the UK Electrical Forum area at ElectriciansForums.net
J
jimjamjimajam
Just been to a rental property where the tenant reports bulbs blow every couple weeks throughout the flat. Have checked fittings and carried out necessary tests etc but cannot see anything obvious.
Appears to have been rewired within previous 5-6 years.
Any suggestions?
cheap lamps is favourite. replace with the halogen ones.
Vibration is a killer for CFL / halogen lamps. If they are jumping around upstairs, or the people could be on the 'large' side, they will be making the light fittings shake, and causing premature failure of the lamps.
I had this with some kitchen fittings. 4 bar GU10, which would get through a lamp every 2 weeks, even with good lamps.
I changed them to LED over a year ago, and havent been back since (I told them the LEDs were guaranteed for 2 years.so they would ring if one failed.)
Reply to lighting fault? in the UK Electrical Forum area at ElectriciansForums.net
Hi we are replacing light fittings in our home. Im confident with the fitting aspect, but have run into doubt in making the right choice of...
Hi all I don't appear to be able to post in the DIY forum so apologies if this is the wrong place. I live in a block of flats with an external...
I am not an electrician but am looking for some advice as to how to fix my sporadic light flickering problem that has come and gone for the year...
Hi all, I have an unusual issue with a recent rewire I have just completed which I hope you guys can assist with. For background, this is a...
Hey folks Apologies if my question is too basic. I am an Electrical Engineer but do not work in the field. I am looking for feedback to ensure...
