Discuss Lighting help needed.. in the UK Electrical Forum area at ElectriciansForums.net
dlt27
Hi, I have been asked to install some lighting in a commercial cooker extract canopy as they can’t see while cooking. The existing ones there are glass and have cracked, also don’t give off much light. My concern is the heat as it’s very hot where they want them mounted.
I was just wondering if anybody had any experience of this before and could recommend anything. Didn’t know if using FP and some type of intrinsically safe fitting would work.
Thanks in advance for any replies..
Reply to Lighting help needed.. in the UK Electrical Forum area at ElectriciansForums.net
I’m currently fitting out a gaming van that will be rented out for parties. The van will have 10 TV’s & 10 games consoles as well as some led...
Hi, I need help to find an outdoor wall/step light. It needs to be surface mount but not wider then 70mm as they're to be mounted on the posts...
Hi everyone, after temporary removing a Sonoff that I've installed years ago to do some painting, I'm unable to get everything back to work. I've...
