Discuss Lighting help (wiring) in the UK Electrical Forum area at ElectriciansForums.net
gazdkw82
I've got the following set up
Ex-or lightspot HD PIR dali
2x Jc71361 Dali
I'm a little baffled by the wiring.
The instructions that come with the pir are as follows
The bit I'm struggling with is, what is "switching luminaries"?
It's coming from the switch load but I'm not sure what that is.
The jcc fittings have a ballast which has mains and Dali control. In the diagram, mains supply is taken to the ballast. Where is the switch load going?
'Luminaries' = wise people
'Luminaires' = light fittings
When will predictive text apps learn this?
AFAIK it simply means that the switched output is available for any fittings that aren't digitally controllable. If all your fittings are on DALI, you don't need it.
Reply to Lighting help (wiring) in the UK Electrical Forum area at ElectriciansForums.net
I’ve got the following setup on the stairway (picture included) https://pasteboard.co/15IoYrvn2VgA.webp https://pasteboard.co/2UzMaHCbs1iE.webp...
Hi I'm in need of some advice. First of all i'm not an electrician but do have an understanding of electrics as i come from an electronics...
