Discuss lighting issue in the UK Electrical Forum area at ElectriciansForums.net
L
llywelyn111
Hi,
We have installed some wall lights, the touch ones with three settings. We have a issue that they keep coming on randomly. Even when nobody is in the house they come on when they come home. It's on a TT system, could it be a appliance in a cycle? Small spike in voltage? or a ghost? The lights have been replaced once. Anyone come across this before?
and be sure to lock the doors and leave the lights on when you go to bed. wooooooooo
serves him right for fitting wall lights. these went out with the demise of gas lighting.
if you miss those days, try the amish community. they still won't use electrickery or automobiles
anyway, iv'e got the answer to the problem. it's ethernet. all those strange cyber waves in the atmosphere of the room switching the lights on.
Hi,
Firstly, You need to ensure that you have a good earth, so that the fitting can not pickup stray RFI signals.
As its a TT system, the ZS at the fitting will be in the region of 10-200 ohms, and not fraction of ohms.
The control electronics is being triggered by radiated RFI or conducted RFI.
If that's the case then the control electronics in the fittings are a bad design.
If the interference is conducted type then You will need to fit some type of HF filter,
in-line with the fitting supply, or convert to TN-C-S.
If its the radiated RFI, then you can not do much but to replace the fittings with a different make.
Reply to lighting issue in the UK Electrical Forum area at ElectriciansForums.net
Hi Guys I've fitted a few emergency lighting circuits to both domestic and commercial installs before, I've come across one I can't get my head...
I have an issue with a home lighting circuit 6A RCBO provides power to 13 bulbs which randomly keeps tripping, when I say randomly it keeps...
Kitchen led lights have all of a sudden dimmed by about 30% no dimmer in the system. There are 2 switches for this set of lights. Regardless of...
Hello, I’ve got an issue driving me crazy and can’t get anyone to figure it out as it’s not their issue. We had a new extension, single rear...
