Discuss Lighting spur off ring main in the Canada area at ElectriciansForums.net
E
Earthy
Is it ok to spur off the socket ring if an adequate fuse is inserted between ring and wall lights? Reason, I'm 2330 and replaced a like for like chandelier and this was on the light circuit but the wall lights were on the spur(off the ring)... told the electrician that this should have been noted on the consumer unit. Is all ok?
Yes, it should be as visible as any other switch, not buried under floor or in back of fitted wardrobe etc. Have seen and found (eventually) both. Dont know about making notes about it at CU.
This is where things seem slightly strange.....possibly massive over regulation and yet, simple things don't seem to be pointed out in the ( hugely complicated, indecipherable) regs.
No names mentioned in this case but the CU only stated circuits , no ampage, no indication of areas covered (ie ring for kitchen, ring for all other habitable areas).
Competent person or not, most of the public might attempt to solve what they consider to be 'household problems', yet I can't see the rules in place to help them.
The Lec told me it was explained in the paperwork......yeah..... but would your average guy/gal understand a word of that?
Shouldn't dedicated circuits be so.... Lighting(for lightings sake etc) ....we might protect the general public if we can properly protect ourserlves..............?
....please comment, particularly in relation to the CU and DEDicated circuits..........
Reply to Lighting spur off ring main in the Canada area at ElectriciansForums.net
Hi guys, newbie posting! Does the following sound ok... Existing circuit: SOCKET on a ring -> spur to SWITCHED 3A FCU -> SWITCH -> hardwired FAN...
Good evening. Currently sorting out my girlfriend’s flat for rent. I’ve found all sorts of bad electrical work. Can anyone advise if this is an...
Hi, if getting back to the CU is not an option, instead of spurring off a socket via a Sfs putting the rating down to 13a. Could you spur off the...
As I've mainly done site work and moved into domestic recently, I'm a bit rusty on stuff like this, but if I'm adding a loft PIV unit to an...
Ok. Can you cut a ring in half, add junction box, then run a spur off it? I thought it had to be from a socket? Mate of mine wanted me to see if...
