Alright Folks,
Quoting a job for replacing and adding lighting in a church. Currently they have 12 x 6 double fluorescent battens spread across the main room.
They want mood up lighting to illuminate the ceiling (10m high) as a replacement.
I don't think this will be adequate lighting therefore I have advised that the mood lighting should be added as an addition to the main lighting which I plan to replace with a similar smaller LED strip lighting.
Very limited to an chasing or trunking so have I'm going down the wireless route for light controls, most probably RF relays connected to a wireless switch.
My question is..... Does anyone have any suggestions for good uplight fixtures for a powerful uplighting effect (other than standard flood lighting) Also, for alternative lighting to replace strip lighting with the same output without the ugliness ?
