Discuss Lighting Wiring Help in the UK Electrical Forum area at ElectriciansForums.net
dc7615
Would the following attachment be the best way to wire up different groups of lights (each group being operated by 1 switch)? Going from the Consumer Unit into the ceiling rose of the first group of lights and from here to the switch and the other light(s) in the group and then onto the next ceiling rose of the next group of lights, and so on?
are you trying to save a few bob ,if you ring your insurance company first. and you will get the answer ,then come back to us .by the way get a spark in before you make a big mistake .
I would prefer Tel's method, deep backboxes for the switches.How much room do the uplights have as some only designed for one cable.
Thank you so much Murdoch, my first ever dumb rating ! Made my day.:D
i can give you another if you want. but i'm not that mean. i have about 5 dumbs from posters who's sense of humour was abandoned in the test-tube that they were conceived in.
Are you intending to stick all them lights into one protective device? If so then why?
Reply to Lighting Wiring Help in the UK Electrical Forum area at ElectriciansForums.net
Hi all was having a problem with lights work one min not next took ceiling rose cover off to find a stray black wire only terminal free is the...
Hi, have an old bathroom fan. Which has two wires the black and red (line and neutral). The fan has no isolator switch and was powered when the...
can anyone please advise on where the wires go? My electrician installed a new cable ready for when I bought a security light. The cable as shown...
Evening all, I had a quick Friday afternoon domestic job that has turned into a PITA and I'd appreciate your help. While adding some new lights...
