Discuss Lighting with no rcd in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
APE37
HI guys,
just wondering if I can pick some brains. Going to install a loft light and switch off a lighting circuit and the circuit don't have rcd protection, as cables are on surface I don't believe Rcd is needed. What I am doubting myself a little with is my work mate says I need to install bonding to bathroom as I will be taking responsibility for all the circuit. I thought that my addition should meet regs and ensure main bonds in place and existing (I.e no presence of supp bonds and Rcd for existing wiring )should be noted on minor cert. unfortunately I am so used to working on newer stuff at mo and others have said different I am starting to doubt myself. Just thought I would get others opinions here.
Cheers
APE
I'd say crack on with it, you are not putting anything in the bathroom so why be bothered with supp bonding.
if you were making changes in the bathroom, then that's different.
Hi guys,
just thought I would reply as have today off now, thanks for answers. Really appreciate it. Thought I was right but when someone says different you start to think and doubt sets in.
Anyway thanks a lot and all the best.
cheers.
Reply to Lighting with no rcd in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
As I've mainly done site work and moved into domestic recently, I'm a bit rusty on stuff like this, but if I'm adding a loft PIV unit to an...
I live in Australia; you can use a socket tester to test the RCD for the power outlet circuit. Plug device to a 3-pin wall socket, set testing mA...
Hello! I've been racking my brain this evening about some RCD selections. I've been doing some work for a solar installer, and they've asked me...
An RCD keeps tripping. Please see attached photo of the board (2 photos attached). I’ll call the breakers: MCB (1) marked ‘Upstairs lighting’...
Hi I'm in need of some advice. First of all i'm not an electrician but do have an understanding of electrics as i come from an electronics...
