Discuss Lights constantly on with timer in the UK Electrical Forum area at ElectriciansForums.net
try the manual override if it has one. either waylooks like it's time for a new timer.
"It is a countdown time."
Hi. It would be helpful to have a bit more information.
are you stating cause and effect? - are you talking about a lightswitch?
Is it in your home, or in a public area?
If a lightswitch, Do you know the make?
Is it pheumatic, mechanical, or electronic?
how about a picture?
sorry to answer with a load of questions, but difficult for anyone to make any suggestions without more to go on!
It is a manual rotary intermatic 30 minute countdown timer. I am working in a module that has a lower level and upper level. On the lower level there is the same timer and it works properly. The one on the upper level does not work at all. Lights are on all the time.
Hi
that's really helpful
is it like this: https://www.intermatic.com/en/in-wall-controls/spring-wound-countdown-timers/ff30mh
or the photo below.
as a clockwork timer, if the knob doesn't wind back to 'off' by itself, I guess the mechanical mechanism is faulty, in which case it would be cheaper to get a new one rather than repair the existing (Unless you happen to be a watchmaker turned electrician!)
Mind you, if turning the knob to 'off' doesn't make the lights go out, it must be a faulty microswitch in the timer, (or some other strange electrical fault supplying power to the lights). Replacement of a faulty microswitch might be possible.
You need an electrician with a meter to check if it's the microswitch stuck, of if there is another fault.
Hi
or the photo below.
The timer is like the photo. The timer works properly. Does it matter where the hot goes on the line or load? There are two black wires coming out the back of the device.
It shouldn't matter which way round it is connected.
if you can isolate the supply, you could try disconnecting one or both wires, keeping them away from each other and everything else (preferably insulating them), turn the power back on and make sure the lights no longer come on.
That would confirm the switch is broken!
I suspect easiest fix is to buy another timer!
just to be sure. hit it with a 4lb. lump hammer. then you'll know it's broke.
Reply to Lights constantly on with timer in the UK Electrical Forum area at ElectriciansForums.net
I have a countdown timer switch hooked up to run my washroom fan. It stopped working all of a sudden. I replaced it with a regular switch and...
I'd like to find a timer switch, in a style that looks alright next to decora light switches, to control a bathroom fan. The bathroom fan...
Hi I replaced a Flash immersion timer with an apt one today and it seemed straightforward but just wondering should the light on isolation switch...
Hi all, Wondering if you could offer some advice please. I carried out a small outdoor lighting project today at a commercial property. 4 lights...
I
Hello folks. Just looking for a little help please. Recently I fitted a fst77 timeguard for a single 2.5kw simplex model NLSH18MN. This works...
