Discuss Lights not working Help with fault in the UK Electrical Forum area at ElectriciansForums.net
hi guys
I'm currently Doing a fault find on lights not working.
I got 230v between live and cpc, 230v between live and netural. Am I correct in saying we have a dropped put neutral at some point along the circuit!
hi guys
Where exactly have you taken these readings from, how many lights are involved?
Reply to Lights not working Help with fault in the UK Electrical Forum area at ElectriciansForums.net
Hi everyone. Hopefully someone can help with a little mystery i had today. The issue is fixed but I want to understand what was going on to help...
Evening all, I had a quick Friday afternoon domestic job that has turned into a PITA and I'd appreciate your help. While adding some new lights...
Hi everyone, I'm new to the industry(Qualified a few months ago). I have a client with 6 LED light fixtures on the same circuit/breaker, 3 are...
Hi all, Just a quick one, I want to use an ip rated light switch with a neon indicator to manually ovveride a PIR detector controlling an e27 LED...
