Discuss Lights trip out RCD but on other side of DB in the Canada area at ElectriciansForums.net
If a lighting circuit was tripping out the RCD evan though the circuit is not on the RCD side of the DB, Check for a shared neutral. The RCD will detect the imbalace.
Definately sounds like you have a nuetral adrift somewhere, I presume the dis board is a split load db, just make sure all the nuetrals on the rcd protected circuits are seperated from all of those on the main switch side. and that they are all in the correct nuetral bars.
Reply to Lights trip out RCD but on other side of DB in the Canada area at ElectriciansForums.net
Called out to fault on RCD tripping maybe twice in a month for sometime. Did all the tests & found RCD was faulty, Refitted a new Rcd Type A which...
An RCD keeps tripping. Please see attached photo of the board (2 photos attached). I’ll call the breakers: MCB (1) marked ‘Upstairs lighting’...
Sorry no photos, but I’ll explain best I can. Turn on the switch, I’m not getting any light. Apparently a new fitting. Description…. A white...
Hi, I seem to have an RCD that keeps cutting the power at random times without actually tripping, if I reset it, the power comes on and will stay...
Cant get my head round this :( I understand N-E faults cause RCD's to trip, but I cant understand why on these 2 occasions, googled allover but...
