Discuss Lights trip out RCD but on other side of DB in the Canada area at ElectriciansForums.net
W
wamarsh
Hiya
Installed a ne MK 12way Split load DB. When a lighting circuit is energised, the RCD trips out. This lighting circuit is on the non RCD side of the DB. By the way the lighting circiut does not have a CPC ( Built early 70's ). Looks like I will have to start breaking the cicuit down and get the old Megger out.:confused:
Did you see the the mistake. No Earth? Never work on an installation with no earth. This installation requires a total rewire. If a customer does not want to pay, walk away. Remember, Its your name on the paperwork.
Reply to Lights trip out RCD but on other side of DB in the Canada area at ElectriciansForums.net
Hello All, I am a homeowner (but not an electrician) and I am renovating a house that has an old CU containing MCBs and an MK LN5725 residual...
Good evening, I have recently moved into a new home and I am having problems with the MCB/RCD tripping (Mem M6 Type 3 - 30mA). It intermittently...
Hi all. Have an issue i'd love some advice on if anyone would be so kind. Will try to be brief. Thank you!! So, have an intermittent RCD trip at...
