kreatiff63
- Reaction score
- 8
thanks for your help, amazed you hung on so long actually Really appreciated it.Don't cut into anything before understanding EXACTLY what it is. Preferably don't cut into anything full stop!
Please deal with this in an analytical manner, which you should be capable of if testing s/w professionally.
You need to understand what cable does what and goes where in your existing wiring, map out what needs to be done, and test the validity of your assumptions (eg using a meter) before actually connecting anything.
Don't just try things out to see if they work. Electrics should be done with test equipment and logic.
I'm leaving this, hoping you either get someone in to help/do it, or you spend a lot more time reading up, investigating, testing, using logic and gaining certainty about your existing wiring before trying to connect anything up.
