Discuss Lights won’t turn off in the DIY Electrical Advice area at ElectriciansForums.net
I have four can lights in my kitchen that are controlled by two switches on opposite sides of the room. Recently, when you try to turn those lights off by the switch opposite switch from that you used to turn them on they just blink and stay on. This seems to be true regardless of where you start. The on switch that turns them on must be used to turn them off. Any ideas why?
If I've understood you correctly then I would say there is a fault in one of the 2 way switches, or a bad connection with the strappers (the link wires between the two switches)
Has there been any work done to either of the switches? Like changing them to decorative metal or anything where they haven’t been put back correctly?
Or, one of switches has a fault and it’s just not “switching” any more
Reactions: DPG
No work has been done. I’m guessing one of the switches is bad. Thanks for the reply.
Reactions: DPG
Reply to Lights won’t turn off in the DIY Electrical Advice area at ElectriciansForums.net
Hi guys. I will start by apologizing for the elementary question. I'm sure you get them often. The chandelier is in a hallway controlled by a...
Hi New to this forum, Just looking for some advise as a DIY person. I have recently purchased a new home. I have come across a wall light which...
Hi everyone, after temporary removing a Sonoff that I've installed years ago to do some painting, I'm unable to get everything back to work. I've...
Hi All, thanks in advance for any guidance you can provide. I will of course turn off everyhing at the consumer unit before doing anything. I...
