Discuss Link leads in split load board in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
G
gaz26
Hi all. I have got a split load board but the link leads to feed the RCd are missing. Has anyone any views on using the blue and brown out of a 10mm twin and earth to do the links? The RCd it would be feeding is a 80amp RCd protecting a 32 amp, 16 amp and 6 amp mcb's
Reply to Link leads in split load board in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Hi All I'm new here. I have just finished my NVQ and waiting to do my AM2. I have a question on selectivity as it has always slightly confused me...
Hi everyone, A diversity question concerning 2 consumer units fed from 100amp DNO supply Background, So I have an 18th Ed compliant consumer...
Hi everyone, I wondered if anyone could help me with something that has been niggling me please?! When a Solar PV feed in circuit is installed...
I have a 40amp RCD downstream of a 50a MCB (10mm csa cable) should the MCB be lowered to protect the RCD from overload? If so why does this not...
Helloo guys, First post, so sorry if this is dreary! I'll try keep it simple... I have a client with a distribution circuit supplying AC...
