daver
Hi Guys
Go easy, I'm learning.
Went to look at a little job today. In brief TNS, split 25mm tails. First CU is next to service head with 16mm Earth. 2nd CU is about 5m away in new extension with 16mm Earth.
First CU is bonded to Gas with 6mm, and the 2nd CU is bonded to water with 10mm.
I was a little confused, as I understood that both CU's had to be bonded, or if i upgrade the 6mm to gas, does this cover regs.
Although the customer didnt have the certs, he had this signed off late last year.
All the guy wants is a small radial from the extension consumer unit, so I just wanted t clarify.
And is it correct, that I would only need to do Installation Cert for that additional circuit.
Thanks in advance
Dave
Thanks in advance
Dave
