Discuss local authority smoke alarms in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
F
frankmac
Hi Guys ,friends house was rewired 3 yrs ago.........contractor installed 3 x mains powered smoke detectors with battery back up smoke detectors which can can be tested and silenced via double gang test switch...........problem ocurrs approx 9pm each evening ..........sounders start blasting will silence by operating test switch.maybe 30mins later same problem...........tried taking heads off one each evening still the same.Batteries cann`t be changed,good until 20016 so it say on head.
anybody any ideas................tried cleaning them.
Cheers Frankmac.
try going to pub befor 9 and you wont hear them and when you get back you wont care sorry not what you wanted to hear but after a few stellas best i can do
ok lets be serious give us the make and model and ill look into it
Reply to local authority smoke alarms in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
Hi all Recently we've been having a few issues with smoke and heat detectors.. been fitting them for years and years now mostly without any...
Having a bit of a mare at the moment with a small 2 story HMO (6 single rooms with shared kitchen) which was fitted relatively recently (2016 or...
Evening evening had a job spec come through today that read: 'Services required: replace a consumer unit / fuse box Additional information: We...
J
I need to install a fire alarm system to a three storey building HMO. The council has specified an Automatic Fire Detection System to comply with...
4K
Hello electricians, I got myself an Mx4100 fire alarm panel about a year ago from a relative, I unistalled the panel, got yards upon yards of...
11K
